HomeposRunning
robolab
Hi there,
we have to edit an robot with HomeposRunning 5.64.
The virtuell controller works fine, but the sync with the cell doesnt.
The SMove Instructions are ignored.
What can we do!
What can we do!
Hello robolab,
you have to use instruction templates for these move instructions.
You can create this by your own or you can use the attached files for the numerical version of Homepos-Running.
To load this files click in the Home Ribbon onto the small box in the lower right edge of the Path Programming area, so that the instruction template editor will open.
Press the "Import" button and load all the files from the attached ZIP file.
Press the "Validate" button to verify if all loaded templates are okay.
Now the SMove-Instruction will be offered for teaching position.
Best regards
Micky
- 365 IRC5
- 84 OmniCore
