Help! Get the current TCP pose
Hello everyone,
I was following tutorial in the PC SDK Manual and I want to read the current TCP pose in C# with the following:
public void Read_Current_Pose()
           NetworkScanner scanner = new NetworkScanner(); scanner.Scan();
            Controller acontroller = new Controller(scanner.Controllers[0].SystemId);
            acontroller.Logon(UserInfo.DefaultUser);
            MotionSystem aMotionSystem = acontroller.MotionSystem;
            MechanicalUnitCollection aMechCol = acontroller.MotionSystem.MechanicalUnits;
            MechanicalUnit aMechUnit = acontroller.MotionSystem.ActiveMechanicalUnit;
            try
                if (acontroller.OperatingMode == ControllerOperatingMode.Auto)
                   using (Mastership m = Mastership.Request(acontroller.Rapid))
                         RobTarget CurrPos = acontroller.MotionSystem.ActiveMechanicalUnit.GetPosition(CoordinateSystemType.WorkObject);
                         RapidData rd = acontroller.Rapid.GetRapidData("T_ROB1", "Module1", "rbt")
                         CurrPos = (RobTarget)rd.Value;
                         Console.WriteLine(CurrPos);
I wrote rbt:= CRobT(\Tool:=MyTool \WObj:=wobj0); from RAPID but I am not sure if that is the way to write it to get pose. I want to get the current TCP matrix, but when I printed the output it was not was I expected, as I got this output : [[1587.428550103,-522.655533591,0],[0,0,1,0],[-1,1,-2,0],[9E9,9E9,9E9,9E9,9E9,9E9]];. Please what am I doing wrong?
Any help will be appreciated. Thank you.
David
  • the pose consists of 2 parts a pos [x,y,z] and a rotation [q1,q2,q3,q4]
    the layout you'r gettin is the complete robtarget which consists of a [pos][rotation][config][external axis]
    The values u are getting are related to wobj0 which is usualy equal to the robot base frame
    RobWelding
    The Netherlands
  • Thank you very much Sjoli. I understand better now. Since I am getting myself familiar with PC SDK with Robostudio my knowledge is still limited. Since the matrix will consist of both rotation and translation, please is there a way to read that into C#? What I actually want to do is to obtain matrix by:
    Move robot to a position --> Read the the current position and rotation that will result in matrix --> Move robot to next position --> Read again --> until all positions reached and read.
    I need a way to approach this sequence. Can you please show some light on how to proceed?? Thanks a lot!!
  • First get the CRobT
    Then you can save the pos and orient(q1-q4) data from the target to there own datatype
    MODULE Module1
        pers robtarget p1:=[[100,200,300],[1,0,0,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]];
        VAR pos pos1:=[0,0,0];
        VAR orient orient1:=[1,0,0,0]
        PROC Example()
            p1:=Crobt(\Tool:=tool0\WObj:=wobj0);
            pos1:=p1.trans;
            orient1:=p1.rot;
    ENDMODULE
    RobWelding
    The Netherlands
  • Following your code and with your help, I am now able to save the pos and orient. Thank you very much. I can write the code to convert them to form the matrix from the C#.... Or is there any better way to covert the output to rotation matrix instead of me writing that code?  ( I need it with the transformation matrix from the camera to make the calibration)
    Once again, thank you very much.
