Un-earasable T_Rob
Hi !  If you look at the pict attached below you will see that i have 3 T_Rob1 under the Default task on my station. I don't know what I do to have all these and I'm not able to remove them. The Delete fonction when I right click on it do nothing.
They are all empty and everything work fine in the station for now.
Anyone know why i have these ??
Thanks !
  • I have exactly the same problem. Dunno how it came to this, because I didn't create the system from the scratch., but I have my suspicion that maybe it's a leftover from deleting the controller. Anyway for now I didn't pick up any problem connected with this. Everything works just fine, except that it may take some memory space, probably.
