How to create a default value for inputs in a function
kentz
I want to achieve something like proc main(a, b, c, d), where input c and d get hardly changed. Is there a default value that i can set to c and d when i can just go main a,b; ?
and when i do want to change c and d value i'll go main a, b, c,d;
Regards
Kent
Yes, they'd be optional arguments.
See how the wobj argument is checked for presence, then only used if present in Example 1:
http://developercenter.robotstudio.com/BlobProxy/manuals/RapidIFDTechRefManual/doc369.html
5
Thank you soup, that's exactly all i need. And you've just pointed me to a awesome place for programming references.soup said:Yes, they'd be optional arguments.
http://developercenter.robotstudio.com/BlobProxy/manuals/RapidIFDTechRefManual/doc369.html0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
