ABB IRB1600 devicenet connect with WAGO I/O 750-340
i can't set the right EIO unit type and unit.
please help me set right data?
thank you
  • did you try to use the device net generic unit type.
  • Use DN_GENERIC in Data type--> restart the system Check the warning message. You will get the details to create unit type. with these data create unit type. Add this in unit.
