RW Plastics Mould on Robot Studio 5
I am unable to load programs or create new programs using Robot Studio 5. I created a system using Robot Studio Online from a backup of a working RWPM system on an IRB1600. I created the proper authorizations using the UAS Administator on RSO. I restored the backup file via the Virtual FlexPendant. The Virtual FlexPendant allows me to try to Load a program, but I get the following error.
Failed to load program
Load Program failed because some file defined in xxx.pgf is missing.
SYS_CTRL_E_GENERAL_FILE_ERROR: General file handling error.
When I try to create a new program via the Virtual FlexPendant, I can name the program in Step 1 but when press NEXT I get the following error:
Create new program failed!
I would like to use RS instead of VC. Can you help.
Best Regards
Jim Proulx
j_proulx2006-4-10 16:24:34
In this release of RWPM the Robot's System folder must reside within the MediaPool folder. This will allow Creation / Loading / Saving of RWPM programs
