Odd or even numbers
                    pavpav
                I would like to check if a value is odd or even, does anyone have a good solution for this in RAPID?
I know its possible to divide a value by 2 and count the amount of decimals, but i cannot find a function that can count decimals.
Thank you
            Check out "MOD" -- IF nYourNumber MOD 2 = 0 THEN
            As an extention of Soup his answer, check out this page to understand the mathematics behind the MOD instruction:It explains fairly well what MOD (A.K.A. Modulo) does.0
 - 363 IRC5
 - 81 OmniCore
 - 853 RAPID Programming
 - 31 AppStudio
