M94 Systems
Sam_BR
I'm trying start a model of m94 robot in QuickTeach v5.3 but when I select a 2.1 system the controller begins start and then give me a memory fault.
Someone knows how fix this problem????
Regards
Marco Scarpelli
Max Motion Automation
Marco Scarpelli
Hi Sam,
It probably depends on yor PC configuration, see the Release Notes:
Due to startup problem on some PC configurations the virtual controller
2.1 is no longer supported. Since VC 2.1 will run without problem on
most PC, we provide VC 2.1 to be used as is.
Thank's Anders, I had already seen the release notes.
But if somebody knows what exactly don't leave
the program of working I would be very thankful .
Regards
Marco Scarpelli
Max Motion Automation0
