Smooth motion?
pollux
I'm sending positions over a socket to a IRB140 which is working great. I'm sending the x/y/z positions and then using MoveL to move the robot to the desired position.
Though I was wondering if there is a way to make the robot move a bit more smooth but in such a way that it sill follows the points I'm giving it?
In this video I'm trying to draw a smooth sin wave (starting around 0:12): https://www.flickr.com/photos/diederick/15160786114/ and you can see how it draws the wave stepwise.
p.
Are you using 'zfine' for your zones?
Hi Neily03,Yes I'm using fine indeed. When I use e.g. z0 it's not creating the path I want it to create.p0
z5 or z10 deviate too much too?
Hi Neily,Thanks. I guess in my situation there is no other way around it but I'll give it a try with a zone like z0. Maybe the result will be good enough.p.0
- 367 IRC5
- 858 RAPID Programming
