Module problems when mirroring a path
When using the Mirror Path function in the Paths&Targets browser, the new path and targets are created in a new module 'Module 1' not in the module being worked on that I have loaded.
If I change the default module name in the synchronization options then the new path and targets are created in the correct module.. but if I deselect 'Use default locations' it still puts them in 'Module 1'. It seems difficult that I have to go into options and change the name each time I load a new module to work on. Is there an easier fix for this?
  • Any newly created path, mirrored or not, will synchronise to Module1... I agree, changing the path to another module does not include the targets and these seem to have to be selected/changed individually.
