sync the robot controller system date/time with a time server
binbin
Hello there,
Is it possible to sync the system date/time of the Robot Controller with a time server?
and how?
BinBin
I'd also like to know this...
If using a time server is not possible, could maybe one controller on the network be the master date/time and all others look to it once a week to tune their clocks...?
Hello soup,Thank you very much for your reply!If I connect the PC and controllers in a network, and use a PC as the master date/time.Do you know how to configure the controllers, so that the controllers will look to the PC "once a week to tune their clocks"?Thanks and best regards,BinBin0
- 365 IRC5
- 84 OmniCore
