PC SDK networkscanner doesn't find robostudio virtual controller and real contr. (service port)
Perla
Hi All,
I am a beginner and I started to develop the first simple c# application that performs the scanning of the network in order to find controllers that is reported in the application manual of PC SDK. I tried to run the application looking if it could scan the virtual controller on robot studio (installed on the same computer of visual studio), but it doesn't work. I tried to run again connecting real controller through service port, but it doesn't work again. Someone can help me? Thank you so much!!!
Perla
hmm,
Have you got your references right on VS ?
How about configuring your ports ? you might have Dynamic IP address. Make it static.
I have written some code that is highly simplified ( for beginners ) using IronPython.
https://github.com/JoyKrishnaMondal/PythonABBDriver
If you run this it should work without config and upload a sample rapid file onto your virtual robot. Make sure to have Roboware 5.15 installed !
ohh i forgot to add ! you need to pass in a third argument in the cmd line , something like "0,0,0" or "0,0,10" if you want the robot to move by 10 mm in the z direction0
I am still working on the project. but in a while I would have exposed a very simple API for anyone to use basic functionality of the robot without hassle : ) I just need help from other ppl like yourself to push it forward.
What exactly do you wish to do with the robot ? just general linear motion or rotation and stuff like that ?0 -
HiCheck that you have the PC Interface option on the controller. Need when working with the PC SDKPer Svensson
Consat Engineering0 -
Its the PC interface option enabled by default ? where can I go to make it default if its not default ?
This reminds me of a problem - I have PC interface enable but I am unable to use Sockets
Any idea what might be the problem there ?0 -
For a virtual controller you check the option when building your system. For a real controller it's enabled if you have a key that includes the option.When communicating with the controller over ethernet you should use the factory network port and not the service port (real controller).Per Svensson
Consat Engineering0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
