Synchronize To Station Issue
I'm having a strange problem with RobotStudio 5.61.02.  (I had the same issue with 5.61.01).  I make changes to my RAPID code and apply, then try to synchronize to station.  The dialog pops up, but only the virtual controller icon is visible.  I wait several minutes, but the tree is not populated.  If I save and close the station, reopen it, then sync to station again once the VC starts up, the tree appears and I can sync with no problems.  Synchronize to VC works with no issues.
I have tried this with three different stations, all with different VCs.
Has anyone else encountered this problem?
Thanks,
Scott
  • An update:  I discovered today that if, after making a RAPID change, I close the RAPID module after applying changes, the synchronize to station operation works just fine.  That's a workaround I can live with, so I'm marking this resolved.
    Scott
