unpack & work error
djhoser
i am triying to unpack station and RS shows it:
Unpacking station...
Restoring backup for IRB7600_500kg_2.55m...
Opening station...
Unpack & Work failed
A Support Log will be created. Please report this error using the RobotStudio Support Tool.
How can i solve this problem...help please.
John 3.16
Is the Pack & Go made in the same version of RobotStudio as you unpack it to? A Pack & Go made in RS 5.14 can not be unpacked in an older version of RobotStudio (for example 5.13).Best regards,
I have the same problem.
I created a station with 5.15.6021 a while back and can't open it with either 5.15.02 (for obvious reasons), 5.60 or 6.00. According to RS, netiher 5.60 or 6.00 is even compatible to open it?The very same error as the one above./Robin_S0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
