Models disappearing?
Robin_S
Hi!
Several times when I've worked with RobotStudio the models I've created (boxes, cones and such) just disappear when I open the station again. In the layout list they are still there, their coordinatesystem (X, Y, Z) are still shown. But the models are not visible or anything.
I right-clicked them and it says they are visible.
I also tried changing the color of them, but right-clicking the models in the list and clicking "Graphic Appearance" merely generates this message: "Unknown Error: Graphic Appearance".
Setting the color changes nothing, it's still just as invisible as before.
So, is there a solution to this error, or should I expect to just "re-do, do right"?
/Robin
Hi Robin,This problem should have been solved in RobotStudio 6.0. Have you installed the latest release?Regards,AndersBest regards,
ABB Robotics5
Yes, I had the 6.00 version too, but I was working in 5.60 at that very moment.But I used a Pack and Go and Unpacked it in 6.00 and the models are there.Thanks for the help!/Robin0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
