Measuring in RS
In which coordinate system the measuring (point to point) distances (x,y,z) are given? Are they always in world coordinate system or in UCS?
Is it possible to change to the desired coordinate system someway?
Regards,
Mika
  • Since the distance is given as a 3D scalar, it does not matter which coordinate system you use.
  • I am not interested the distance itself, but the x,y,z components and they directions... for that I need to know in which coordinate system they are given and can it be changed to get desired "subdistances".
    Mika
