Actual torque of motors
Hi everyone,
I was wondering if there is a way to get the actual value of motors torque in RAPID programming, in order to take decisions depending on their values.
Anyone managed to do that?
Thanks a lot,
Gabriele
Just curious -- what would you do with motor torque values? Detect a hit to be used in a search?
I want to measure the torque of all joints in a precise joint configuration during tuning, then compare all these torques at run time, when the robot is in the same joint config, to verify if the payload held by a gripper has changed.0
Any ideas?0
in RobotWare 6.0 a new function "GetMotorTorque" is introduced.
In the older RobotWare you can maybe use the TestSignal instructions (TestSignDefine and TestSignRead) to get the motor torque.
BR
Micky
1 -
Thank you! That's exactly what I need.Micky said:Hi,
BR
Micky
G.0
