Actual torque of motors
Hi everyone,
I was wondering if there is a way to get the actual value of motors torque in RAPID programming, in order to take decisions depending on their values.
Anyone managed to do that?
Thanks a lot,
Gabriele
  • soup
    soup ✭✭✭
    Just curious -- what would you do with motor torque values? Detect a hit to be used in a search?
  • I want to measure the torque of all joints in a precise joint configuration during tuning, then compare all these torques at run time, when the robot is in the same joint config, to verify if the payload held by a gripper has changed.
  • Any ideas?
  • Micky
    Micky ✭✭✭
    in RobotWare 6.0 a new function "GetMotorTorque" is introduced.
    In the older RobotWare you can maybe use the TestSignal instructions (TestSignDefine and TestSignRead) to get the motor torque.
    BR
    Micky
    BR
    Micky
    Thank you! That's exactly what I need.
    G.
