Trouble with RS 6.00
<p>when editing rapid code the options for find or replace "find next" and "replace" are greyed out, the only option seems to be "find all" or "replace all"</p><p>is this something I am missing or a bug in the software?</p><p>Thanks</p>
  • If I remeber correctly, you can only use "find next" and "replace" when you're looking in the current document (under "look in:", select "current document")
  • that was it, thanks for the help
