Trouble with RS 6.00
                    <p>when editing rapid code the options for find or replace "find next" and "replace" are greyed out, the only option seems to be "find all" or "replace all"</p><p>is this something I am missing or a bug in the software?</p><p>Thanks</p>
            If I remeber correctly, you can only use "find next" and "replace" when you're looking in the current document (under "look in:", select "current document")0
            that was it, thanks for the help0
 - 363 IRC5
 - 81 OmniCore
 - 853 RAPID Programming
 - 31 AppStudio
