VCBin2
bronkhoj
On the robotware 5.07.01.01 CD I found the following directory.
It contains a lot of dll's like Dcl.Jogging.dll
RobotWare CDUtilityVCBin2
Where can you use this directory for?
Can you use it to update your VC on you PC from RobotStudio or VIRC5??
Jan
Hello Jan,
VCBin2 contains files used when developing FlexPendant applications in Visual Studio 2005. So normally you should just ignore those files.
regards,
Johannes
Johannes Weiman
ABB Robotics0
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
