Undo
Just wondering for a future update can we have to ability the undo and redo more than 10 times? Also don't include changes of view in that that as if I change a robtarget for example and then move the view 10 times I can undo the change to the robtarget which is very frustrating...... I can't imagine why anyone would need to undo a change of viewing angle......
  • Hi,
    Changing the view isn't an undoable operation. How did you manage that?
    Regards,
    Johannes
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • Neily03
    Neily03 ✭✭✭
    Sorry I meant "view robot at target', that is an undo able operation which makes it very easy to use up the 10 undo's without actually making any real changes.
  • That's a valid point, I'll put it up as a suggestion along with increased undo limit.
    Johannes Weiman
  • Neily03
    Neily03 ✭✭✭
    Excellent, cheers,
    Neil.
  • In the meantime, here's a little addin that increases the undo queue to 100 steps.. watch out for increased memory usage though!
    http://1drv.ms/1Ey6EB2
    Johannes Weiman
  • Neily03
    Neily03 ✭✭✭
    Excellent thanks.
    I've downloaded and extract the .dll file but what exactly am I meant to do with it, where do I put it?
  • Johannes Weiman
    edited March 2015
    C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio x.xx\Bin\Addins
    C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio x.xx\Bin64\Addins
    Johannes Weiman
  • Neily03
    Neily03 ✭✭✭
    Excellent thanks again.  One thing though, there was no 'Addins' folder in Bin64 so I just created it and it's worked a treat.
    Thanks again.
