Undo
Neily03
Just wondering for a future update can we have to ability the undo and redo more than 10 times? Also don't include changes of view in that that as if I change a robtarget for example and then move the view 10 times I can undo the change to the robtarget which is very frustrating...... I can't imagine why anyone would need to undo a change of viewing angle......
Changing the view isn't an undoable operation. How did you manage that?
Regards,
JohannesJohannes Weiman
Sorry I meant "view robot at target', that is an undo able operation which makes it very easy to use up the 10 undo's without actually making any real changes.
That's a valid point, I'll put it up as a suggestion along with increased undo limit.Johannes Weiman
Excellent, cheers,
Neil.
In the meantime, here's a little addin that increases the undo queue to 100 steps.. watch out for increased memory usage though!
Johannes Weiman
Excellent thanks.
I've downloaded and extract the .dll file but what exactly am I meant to do with it, where do I put it?
C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio x.xx\Bin\Addins
C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio x.xx\Bin64\Addins
Johannes Weiman
Excellent thanks again. One thing though, there was no 'Addins' folder in Bin64 so I just created it and it's worked a treat.
Thanks again.
- 367 IRC5
- 858 RAPID Programming
