AWPP 5.60 - Path From Edges and Base Plate setting - bug?
I'm creating a weld with path form edges template but I'm not able to set base plate because the setting window doesnt work correctly. dunno if it has some connection to screen resolution. Tried it with other computer and it worked fine. Mine is 1920x1200.
Cheers.
-AT
  • Problem was that my text size scaling was set to 125%. Chainced it to 100% and the window seems to be working fine! Thanks to Oskari!
