Payload too large
What is the value of your tooldata (i.e. the TCP)? Does it work if you use tool0?
Kind regards,
Ok, please be patiente with me if I don't give you all the information, I'm just beginning on simulation world.
I used the smart component found here https://robotapps.robotstudio.com/Details.aspx?fileId=f57fc662-5f9b-4d00-be8d-23a7324b23cf to create a Vacuum Tool. I just put the dimensions but the TCP Position was 0,0,200 by default.
In the attached image you can see what I did. Then I just attached to tool to the robot, at that's everything I did.
Thanks for you help
I checked the component and it creates a tool with a payload of 18 kg, which is far too much for the selected robot. You can change the payload in RAPID Editor or in the Paths&Target browser of RobotStudio. If you change it in the browser you need to "Synchronize to RAPID" to update the RAPID code.
ABB0
