Install Problems
RussG
I have recieved the following message on install of 5.07
Error 1904 C:\CmOptions.dll failed to register. HRESULT -2147220473
As a result some of the features of RS do not seem to work.
RUSSELLgee
Director
1/118 Connaught St Sandgate QLD Australia 4017
ph +61738694298
fax +61738693284
mob +61418116644
email russell@manmac.com.au
Director
ph +61738694298
fax +61738693284
mob +61418116644
Hi Russell,
Try typing this in the command prompt (assuming you have English OS):
regsvr32 "C:Program FilesABB Industrial ITRobotics ITRobotStudioBinCmOptions.dll"
If you get a success message you should be OK. Otherwise, try to reinstall RS and disable any antivirus software while installing.
Johannes Weiman
ABB Robotics0
- 343 IRC5
- 70 OmniCore
- 840 RAPID Programming
- 19 AppStudio
