IRC5 OPC Server 15 start/stop
I have a question about communication between Robot OPC och Client.
I have InTouch application that communicate with IRC OPC 15 via FSGateway. Windows 7 sp1.
As I see in the windows control panel - IRC 5 OPC is not a service.
1. How can I start IRC 5 OPC Server ? Is it OPC Client that makes it to start? Which start option for IRC5 OPC should I prefer : inproc or outofproc?
2. What is meaning with Start/Stop buttons in IRC5 OPC configuration?
3. Is it possible to make Robot IRC5 OPC "run as service"?
Thank You.
I would recommend you to get in touch with your local ABB Robotics Service office, check http://www.abb.com/contacts. Since you seem to be based in Sweden, you will find the details for your local office at http://www.abb.se/product/ap/seitp327/d4fc82d62e864f20c125762e004cd845.aspx.
Kind regards,
Henrik
Hi Henrik, Thank You for answer. I have got answer from Support. This Robot OPC server can not be run as Windows service, only as process. Start/Stop buttons are for restart of OPC server after changes in configuration or start OPC in case of process RobOPC stop. Regards, Antonina0
- 348 IRC5
- 847 RAPID Programming
- 21 AppStudio
