How to synchronization the module contains data from external file?
WuYue
I am reading data from external file. Open "HOME:/filename.dat", file1\Read; This data is the coordinate of the robot trajectories. My program works well in simulation. However, I have difficulty to synchronize this program into the ABB controller. This is my steps: 1) I save the module on desktop. 2) I synchronize my Robotstudio to ABB controller 3) I load the module, which I saved on desktop. The teaching pendant generate the error saying cannot find the external file.
Is there any other better way to do the synchronization?
Thanks!
Hi, You need to use the "File Transfer" in the controller tab to place the .dat file in the home folder.Best regards,
ABB Robotics5
