error 10068
I am a new RobotStudio user. I am getting a 10068 error with a system that I just created. Please advise.
I alo get this error everytime I want to ''Move along path'' or play simulation...Anyone know how to solve this?0
This code is a Operational event, so read others messages before this. You should get more info about why the robot can't start the program. More info about this code: 10068, Start Program Description Unable to start program for task arg. Consequences The program will not execute. /BLueIcaor0
Where can I get more info about this error?0
Operating manual trouble shooting. When it comes to play simulation you need a main routine with a call to your path otherwise it will fail.Per Svensson
Consat Engineering0 -
And how can I set main routine with a call to my path??0
Sometimes you get this error when there is an error in the RAPID code. What if you sync to RAPID and then press "Check Program" in the RAPID tab?Henrik Berlin
ABB0
- 350 IRC5
- 848 RAPID Programming
- 22 AppStudio
