error 10068
I am a new RobotStudio user. I am getting a 10068 error with a system that I just created. Please advise.
  • I alo get this error everytime I want to ''Move along path'' or play simulation...Anyone know how to solve this?
  • This code is a Operational event, so read others messages before this. You should get more info about why the robot can't start the program. More info about this code: 10068, Start Program Description Unable to start program for task arg. Consequences The program will not execute. /BLueIcaor
  • Where can I get more info about this error?
  • Operating manual trouble shooting. When it comes to play simulation you need a main routine with a call to your path otherwise it will fail.
    Per Svensson
    Consat Engineering
  • And how can I set main routine with a call to my path??
  • Sometimes you get this error when there is an error in the RAPID code. What if you sync to RAPID and then press "Check Program" in the RAPID tab?
    ABB
