RobotStudio .NET exception: Product installation is failed for new system creation Internal Error
Andraz23
with RobotStudio version 6.01.01 I always geat error pictured bellow:
http://shrani.si/f/2o/13g/BnCaCcG/3.jpg
http://shrani.si/f/2B/Pw/48Wf2yYp/1.jpg
Ii is interesting that version 5.61 works fine. I already tried to reinstal version 6.01.01, then repair it, still error.
Please help me with my problem!
Andraž
If you select the add-ins tab do you have any RobotWare installed?Per Svensson
Consat Engineering0 -
Yes there is RobotWare installed! I Also noticed this problem: http://shrani.si/f/3K/vs/4QaGyX25/untitled.png . I don't know if there is a problem in installation or I should change some mettings here..0
Seams like there is something wrong with RW 6.01.1010 installation. Have you tried with the 32bit RobotStudio (instead of 64 bit)Per Svensson
Consat Engineering0
