RobotStudio questions
JimT
Can I run a licensed copy of RS in a virtual machine?
Have been using the online version with no problems on VirtualBox, just wondering if it is possible to create system from backup in a VM.
Which version of RS should I use for RobotWare Versions 5.09.6003.06 and 5.15.9024.09?
JimT
Hi, Yes you can run RS in a virtual machine, the only limitation is that the trial license is disabled. We only test with VMWare though. And you should always run the latest version
Regards, Johannes Johannes Weiman
RobotStudio Team, ABB Robotics0
- 367 IRC5
- 858 RAPID Programming
