One or more parts of this Link has been removed! Mechanism compilation problem
TiborG
Hi to all,
I'm trying to build an external axis (a positioner in my case) with the Create Mechanism wizard but after completing all the steps and having all the icons green, clicking on Compile Mechanism gives the error 'Could not compile mechanism'. After that, the Links icon gets red and the problem is that the 1st link (which I use as Base Link also) gives the message 'One or more parts of this Link has been removed' and there is no part in the window.
I will be greatful for any help!
Thanks in advance,
Tibor Gyorgy
hi Tibor, I also have the same problem and struggling with it. I need a solution for this problem, because I need to work on mechanisms for my educational purpose. Please help me, if you have the solution. Thanks0
- 367 IRC5
- 858 RAPID Programming
