VSTA doubt
Hi! I understand you perfectly fine. No worries. We have left VSTA behind us. Sorry but we have some problems with formatting forum posts now. Hope you can read this: From Release Notes of 5.60: "2.1 VSTA is no longer installed From RobotStudio 5.60 onwards, VSTA will no longer be available in RobotStudio. This has the following implications: The IDE is not available. Macros will not be executed. Stations and libraries with macros can be loaded, but the macros will not be executed. 2.2 Switch to SmartComponents or Visual Studio The C# or VB.NET code in a VSTA macro can be migrated to a Visual Studio 2012 Express C# project, and you can continue development using Visual Studio. In case you have a macro that is used in together with the EventManager, you also have the option to implement the same functionality using RobotStudio SmartComponents, instead of using Visual Studio and C#. If you want to migrate another macro, ABB recommends using Visual Studio 2012 Express." https://library.e.abb.com/public/047ce368b47b600483257c990052a31a/ReleaseNotesRobotStudioSDK560.pdf0
Thank you!
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
