Smart Component Gripper doesn't work.
I built a station which picks and places a box with vacuum gripper. I added and connected all necessary components to the gripper. However, the gripper doesn't pick the part when RAPID program is executed. I don't know why. Can anybody help with?
BR,
  • Pack&Go is attached.
  • Hi,
    For the smart components to work you have to use the simulation controls (on the simulation tab) not run the RAPID directly.
    Regards
    Graeme
  • Hi,
    Yes, I know. I've done simulation setup and station logic. And then I started the simulation test by clicking 'Play' on simulation tab menu. I wonder if I missed anything while creating smart component and connecting I/O signals to the gripper.
    Regards,
  • Hi,
    When I run the simulation, the line sensor detects the tool geometry instead of the box. You can fix this by making the tool undetectable:
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • Hej,
    You got it. the gripper is now working.
    Thanks. Tack so mycket. :
    mvh.
