Error 50021 Joint Position Error
henriqcm
After a movement with speed 1000 a ABB IRB 120 that i use in work is giving this error.
Actual position of Joint rob1_3 is too far away from the ordered position.
I think the arm is stucked, because even if i press the break release the arm does not move.
What is it? What should i do?
up0
Check that there is 24 volt getting to the brake on the axis 3 motor (can you hear the brake coming on and off?).
If so follow the instructions in the manual to remove the drive belt from the axis 3 motor, if you can then move axis three the issue is probably in the motor.
Or get an ABB technician to find and correct the fault.
Is axis 3 the only one involved? (Can you jog the other axes?)
If it can be safely done, can you have someone else try to move the robot with the brake released?0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
