Remote I/O - AllenBradley 1794 ADN
Ivonne
Hello everyone, I'm confuse and hope someone can help me.
I'm trying to connect a DSQC 350 to an AllenBradley 1794 AND.
Do I have to connect X8 and X9 (Line1, Line2, Shield, Cabinet Ground) to PLC module?
Main connection of AllenBradley 1794 must to be connected with DN master???
Best Answers
We have used the 1747-SN remote I/O scanner with the DSQC 350. The 1794-ADN is a Flex I/O DeviceNet module. I could be mistaken, but it seems to be a different protocol.5
There is the need to connect X8 and X9 (Line1, Line2, Shield, Cabinet Ground) to PLC module.
You must try by using the 1747-SN remote I/O scanner with the DSQC 350.
It is a 1794-ADN is a Flex I/O DeviceNet module.
But it has the different protocol.
5
Actually I connected the 1794 adn, dsqc 651 and dsqc 350 in a node with DN 603. I haven't used the Remote I/O yet cause I don't have a PLC.0
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 24 AppStudio
