Robot Studio not saving Screen layout
xlr8tor
I use dual monitors and prefer to customize my screen layout so that all tabs are visible at all times. It seems that for the past year each new version of Robot Studio that has been released has the same issue.where each time I open the program I have to expand the window out and place my tabs in the locations for me to begin work. RS 5.15 did not have this issue. Is there a setting that I am missing?
If you mean that the RS main window isn't maximized then when you have started RS right click on the rs icon in the taskbar and select properties on the RS icon and change run to maximized.
Per Svensson
Consat Engineering0 -
This would work ok if I were running a single monitor but I am running duals. Still working on this...
- 364 IRC5
- 83 OmniCore
