Johns Toolbar for RS 5.07?
Is there a function in RS 5.07 to control the playback speed of the robot when you "move along path" or press play to run the path created?
I am making video captures for proposals for customers and if the geometries are simple, it will playback too fast (even if the process timer shows the accurate time). John's toolbar used to have a feature to control playback speed and not effect the process timer calculations.
Thanks,
Allan
You can change to time-sliced mode which will slow down the process a bit. This can be done by the command "tools-options-Simulation-virtual time" and change the setting to time-sliced mode.
/Christer0 -
I have found that if you use the teachpendant to start the program the simmulation seems to run at normal speed.
Russ
RUSSELLgee
Director
1/118 Connaught St Sandgate QLD Australia 4017
ph +61738694298
fax +61738693284
mob +61418116644
email russell@manmac.com.au0 -
Thanks for your help. It works perfectly now.
Allan
