RunRoutineButton and Cancel Call Routine
soup
I'm having trouble with the RunRoutineButton. The problem that I'm having is that I use this button to call a procedure, then if the procedure needs to be interrupted, the program gets bound up and the user has to switch to manual, navigate to the Program Editor, and remember where Cancel Call Routine is... This is unacceptable in production but I don't know what I can do about it. Suggestions?
Did you find a solution? I am facing the same problem.
Nope.
Finally I used a programmable key to perform a "Move PP to Main".
HTH
Sorry, I can't have it Start At Main.
Please help. Anyone?
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
