Which setting is necessary to keep the controller permanently in single cycle mode?
JHesse
Hello everybody,
I would like the controller to stay in single cycle mode (instead of continuous mode) even if the power supply is switched of. Is there any possibility?
Thank you!
Jonas
Thank you!
Jonas
In the system parameters you can set the system to stay in single cycle mode:
5
Hello
You can put Stop; at the end of your code
/Pav0
