Robot writin on desk
Hello everyone, At first I'm sorry for my English.
I want do program that robot IRB 120 write on table word that person write on flexpendant. How I should this do ? I think I should do one letter-one module and then call individual letter. But I dont know how I should do that one string ex.("Hello") program generate module for every letter.
  • Hello
    You can have different procs/routines for each letter which you can call with a another proc that reads the input string of the word you want to write
    Here is example:
    MODULE PROG
        PERS string sText;
        PROC main()
            prWriteText "Hi";
        PROC prWriteText(string sText)
            VAR string sStringPart;
            VAR num nLenght;
            nLenght:=StrLen(sText);
            FOR i FROM 1 TO nLenght DO
                sStringPart:=StrPart(sText,i,1);
                IF sStringPart="H" OR sStringPart="h" THEN
                    prMotion_for_H;
                ELSEIF sStringPart="I" OR sStringPart="i" THEN
                    prMotion_for_I;
                ENDIF
            ENDFOR
        PROC prMotion_for_H()
            !Robot motions for H letter
        PROC prMotion_for_I()
            !Robot motions for I letter
  • Thanks Pavel for response, I'm going try it and then I ask again if I will have doubt. And one more question, How I do that the next letter is moved by a set distance ?
  • Hello St4rk
    You can add an offset to the FOR loop, so for each loop cycle it will add 100mm offset starting from 0.
    See example:
    MODULE PROG
        PERS string sText;
        PERS num nLetterDistance;
        PERS robtarget pWrite_H_1;
        PROC main()
            prWriteText "Hi";
            VAR num nLenght;
                nLetterDistance:=(i-1)*100;
                    prMotion_for_H;
                    prMotion_for_I;
                ENDIF
            ENDFOR
            MoveL Offs(pWrite_H_1,nLetterDistance,0,0),v1000,z50,tool0\WObj:=wobj0;
    ENDMODULE
