Help!! Gripper activating after releasing part w/o signal
shown below is the code for placing a part in a machine and after the gripper releases it will reclamp w/o a signal before moving out of machine. Any suggestions?
PROC Place_VC_Gauge()
PckPlc:=0;
MoveL Offs(pPlc_VC_Gauge,200,0,400),v1500,z100,tGripperA\WObj:=wVC_Gauge;
MoveL Offs(pPlc_VC_Gauge,0,0,200),v1500,z20,tGripperA\WObj:=wVC_Gauge;
MoveL pPLC_VC_Gauge,v300,fine,tGripperA\WObj:=wVC_Gauge;
Set GripA;
WaitTime 0.5;
!GripLoad load0;
MoveL Offs(pPlc_VC_Gauge,0,0,150),v1500,z20,tGripperA\WObj:=wVC_Gauge;
MoveL Offs(pPlc_VC_Gauge,300,0,400),v1500,z100,tGripperA\WObj:=wVC_Gauge;
RETURN ;
Your code looks good -- fine point, then trigger signal.
I guess -- check your signal settings.- Miss mapping of signals?
- Mistaken GripA crossconnect?
- Multitask changing I/O?
- I/O unit setup / messed-up?
- Wires crossed?
- Gravitational pull of the moon?
Blocked exhaust port on gripper?0
What about the code after because the program pointer runs ahead of the motion which can do that I/O is executed ahead. Use Trigg instruction to control the IO signals during motionPer Svensson
Consat Engineering0
