Help!! Gripper activating after releasing part w/o signal
shown below is the code for placing a part in a machine and after the gripper releases it will reclamp w/o a signal before moving out of machine. Any suggestions?
PROC Place_VC_Gauge()
        PckPlc:=0;
        MoveL Offs(pPlc_VC_Gauge,200,0,400),v1500,z100,tGripperA\WObj:=wVC_Gauge;
        MoveL Offs(pPlc_VC_Gauge,0,0,200),v1500,z20,tGripperA\WObj:=wVC_Gauge;
        MoveL pPLC_VC_Gauge,v300,fine,tGripperA\WObj:=wVC_Gauge;
        Set GripA;
        WaitTime 0.5;
        !GripLoad load0;
        MoveL Offs(pPlc_VC_Gauge,0,0,150),v1500,z20,tGripperA\WObj:=wVC_Gauge;
        MoveL Offs(pPlc_VC_Gauge,300,0,400),v1500,z100,tGripperA\WObj:=wVC_Gauge;
        RETURN ;
  • soup
    soup ✭✭✭
    Your code looks good -- fine point, then trigger signal.
    I guess -- check your signal settings.
    • Miss mapping of signals?
    • Mistaken GripA crossconnect?
    • Multitask changing I/O?
    • I/O unit setup / messed-up?
    • Wires crossed?
    • Gravitational pull of the moon?
  • Blocked exhaust port on gripper?
  • What about the code after because the program pointer runs ahead of the motion which can do that I/O is executed ahead. Use Trigg instruction to control the IO signals during motion
    Per Svensson
    Consat Engineering
