Which ports have to be open to access the robot controller through VPN?
I'm trying to reach a robot over VPN.
By opening port 5512, 5513, 5514 and 5515 it's possible to connect to the robot, but I'm unable to browse the RAPID or even take backups..
The ports 20 and 21 is also open.
I got this error in RobotStudio today:
Best Regards,
Kilde
The below information is in the RobotStudio help.
Regards
Graeme
Network connection
To enable a connection to a controller on a subnet or over the local network, the relevant network traffic must be allowed through any firewalls between the PC and the controller.
The firewalls must be configured to accept the following TCP/IP traffic from the PC to the controller:
UDP port 5514 (unicast)
TCP port 5515
Passive FTP
All TCP and UPD connections to remote controllers are initiated by the PC, that is the controller only responds on the given source port and address.
Firewall settings
The firewall settings are applicable irrespective of whether you are connected to a real controller or a virtual controller.
The following table describes the necessary firewall configurations:
- NameActionDirectionProtocolAddressLocal ServiceServiceApplicationRobNetscanHostAllowOutUDP/IPAnyAny5512,5514robnetscanhost.exeIRS5ControllerAllowInUDP/IPAny5513Anyrobnetscanhost.exeRobComCtrlServerAllowOutTCP/IPAnyAny5515robcomctrlserver.exeRobotFTPAllowOutTCP/IPAnyAnyFTP(21)AnyNameActionDirectionProtocolAddressLocal ServiceServiceApplicationTelnetAllowOutTCP/IPAnyAny23RobotStudio.exeIn-Sight ProtocolAllowOutTCP/IPAnyAny1069RobotStudio.exeIn-Sight DiscoveryAllowIn/OutUDP/IPAny10691069RobotStudio.exeUpgrade port (PC only)AllowOutTCP/IPAnyAny1212RobotStudio.exeDataChannelAllowOutTCP/IPAnyAny50000RobotStudio.exe
6
Nobody knows? Not even where to look?0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
