PC Interface & Ethernet IP M/S conflict
Hi all,
We usually purchase robots with the PC Interface option so that the robot can be connected to over a network. This works fine when we purchase the Profibus option for communication to other industrial devices but it seems when we  purchase the Ethernet IP Master/Slave option we can't set the IP address of the WAN port to the same network as the LAN3 port used for communication.
Has anyone been successfully able to set the IPs of the WAN and the LAN3 to the same network range? IE. 123.456.789.1 and 123.456.789.2?
Thanks,
  • Generally, the Spanning Tree Protocol doesn't permit two interfaces in the same range, but if you've done it elsewhere, then I may be way off-base.
