Signal Analyser time resolution
tobyUCT
tobyUCT
edited January 2016 in RobotStudio
Hi there!
I recorded a simulation of my program and I realised, that the recorded parameters are only saved every 24 ms. Is there a way to record more data? 1 ms would be best of course, but that might be a bit utopian..
EDIT:
I found a setting to increase the simulation resolution to 12 ms, however the signal analyser still records at 24 ms.
Cheers,
Toby
Post edited by tobyUCT on
