Is it possible to get safemove to work in RobotStudio?
I've made a SafeMove configuration in Visual Safemove in RobotStudio 6.02.01 64bit. Is it possible to write this to the virtual controller and e.g. see how my MTZ zones work? I've tried this but the safe output signal connected to my MTZ does not seem to be activated when jogging in and out of my MTZ.
On the real controller you need to activate the config with a pin code but this is not possible on the VC since the "Authenticate" menu is not accessible i RobotStudio.
Any tips?
/David
Best Answers
  • Hmm, ok. I have a colleague who says he has done this but maybe he was mistaken. How sure are you Johannes?
    Thanks for your reply!
    /David
