Zone property of a Move-command
Hi there!
I was experimenting with the Zone field of the move command. Sometimes I understand what's happening, but then again there are cases where I have no clue...
To my understanding, the figure after "z" depicts the radius in which the robot is allowed to deviate from the original path.
I have 4 points at 0/0/0, 0/50/0, 50/50/0 and 150/50/0
My 1st path is
MoveJ point1 z0
MoveL point2 z50
MoveL point3 z50
MoveL point4 z0
It starts exactly at z0, then cuts round corners in an S-shape around point2 and 3 and ends at point4. This works totally as expected. The radius of z50 is too big and the actual radius decreases to a value. (point1 is all the way to the right, point2 is the next one to the left, then point3 and 4)
However if I switch the Zone of point3 to z0 I'd expect the curve to cut a big corner around point2 and the end up exactly at point 3.
Can someone explain this to me?
Cheers,
Toby
  • Hi Johannes,
    thanks a lot for the quick reply :)
    The tip about the visualization is also very useful!
    Cheers,
    Toby
