Could not compile mechanism
When I create a new mechanism and compile it I get following error message "Could not compile mechanism". It has something to do with my PC locally since it works OK on my colleagues PC.
I have tried to re-install Robotstudio as well as create a local user account but nothing seems to work.
I really need to get this fixed ASAP, any help would be appreciated.
I use windows 8.1
BR
Johan
I use windows 8.1
BR
Johan
Hello
Try to expand the window size of the mechansim window which may help you, there is a bug which is fixed in 6.03.
/Pavel0 -
That worked
Thanks a lot Pavel
